mjbst111 said:
since you were so strong about putting me down please tell me again of what information i am ignorant. I don't even know what you are arguing. You can't adjust disk breaks! emergency break yes, but only when you apply new pads! quit sitting there calling me ignorant for saying everything you did!
I didn't try to, and am not trying to start a flame war. Check your original post about disk brake calipers:
"you don't ever adjust calipers, ever.
it was a ridicules thing to say. but you guys have to sit there and try to prove an invalid point. it is ridicules.
no one ever does it so why try to prove it.
hey my car feels sluggish today. i better adjust my drum brakes that that i don't even have."
As the GM and Alfa pages show (which are actually European Girling and/or Bendix brakes), the emergency brake is an
integral part of the caliper and disk brake assembly. If the emergency brake mechanism is not adjusted properly, the normal brake mechanism won't work. They use the
exact same disk, pads and caliper.
From GM:
"When installing rear disc brakes with calipers that have an internal parking brake
you must adjust or set the calipers when installing. Failure to do so will prevent you from getting a firm pedal and you will have no rear brake function. You must also set the parking brake every time you park to keep the calipers adjusted."
I still maintain that this clearly says disk brake calipers are adjustable, in GM's words not mine. (I guess we could debate if anything GM says is true, but that's not the point.)
If it is adjusted too tight, it will bind against the disk continuously, wearing the pads and disk, reducing gas mileage and performance, which was the original discussion.
I know this *painfully* from first hand experience with my (formerly owned) '87 Fiero GT.
So,
in my opinion, your statement:
you don't ever adjust calipers, ever. vs. GM
your statement is wrong, which is OK! But...
no one ever does it so why try to prove it. "
ridicules the original poster, EPJ, who was right (which agitates me).
Perhaps we will have to agree to disagree, and that's OK with me.
