Name M998 HMMWV
Manufacturer AM General
Manufactured June 17, 1986
Cargo capacity 2,500 lbs
Towed load 3,450 lbs
Height 69 in (5 ft 9 in, reducible to 55 in)
Length 180 in (15 ft)
Width 85 in (7 ft 1 in)
Gross vehicle weight Tare: 5,200 lbs
Gross: 7,700 lbs
Pintle height approx. 28"
Ground clearance Under axle: 16 in
Under chassis: 24 in
Vehicle/bridge classification Empty: 3
Loaded: 4
Wheel base 130 in (10 ft 10 in)
Approach angle 72° (47° with winch)
Departure angle 45°
Turning radius 292 in (24 ft 4 in)
Cruising range 300 mi
Fording depth 30 in
Tires 36x12.5-16.5 LT
Tire inflation Front: 20 psi
Rear: 22 psi
Engine
Engine Model DDA 6.2 L
6.2 liter V8 diesel, liquid-cooled, naturally aspirated
Power 150 HP at 3,600 RPM
Torque 260 pound-feet at 2000 RPM
Displacement 379 cu. in. (6.2 liters)
Engine weight (dry) 650 lbs
Idle speed 625-675 RPM
Operating speed 1500-2300 RPM
Oil pressure at idle (min) 15 psi
Oil pressure at normal operation 40-50 psi
Coolant temperature 190°F to 230°F
Fuel consumption 13.5 mpg
