Instead of the F8 route, you can also go to Start-Run-Open "msconfig". Then on the "BOOT.INI" tab check "/safeboot" and Ok and then a prompt will appear to restart your comp in safe mode. Once you make your changes go back and repeat the same steps, except you uncheck "/safeboot" and you will reboot normally. Hope that helps.
