ahhhh, fly wheels q's. the fly wheel is mass for the engine to rotate before the power is past your tranny, so the lighter the better. if you have a light flywheel, there is less mass for the crank to turn, so your engine doesn't work as hard. also it provides more throttle control. my buddy has a super super super lightweight flywheel, and although its hard to execute good double clutches when i'm used to my OEM flywheel, i can definately see how you can be more accurate with a light flywheel.
