Help with heater. Front heat doesn't work rear does
Messages
1
Likes
My daughter's 2004 X5 currently has heat in the rear vents. However, it is only Luke warm when switched to defrost or front vents. It's winter time in Alaska and really need to get this fixed.
Would it be the heater core? I figured if that were bad the back heat wouldn't work.
I have disassembled under the dash to gain access to the vent tubing and fresh air door, it works and switches the vest when the floor to vent is selected.
I have also replaced the HEATER CONTROL VALVE but still don't have heat to the front
Can anyone please help with this? Thank you.
Messages
3
Likes
Location
Houston
#2
